Quodpipax
Can't make custom boot logo works
Tue Aug 01, 2017 6:35 am
So, here is my problem:
Did everything right (it seems).
Even though I know how to change it, I read THIS MANUAL.
And still nothing, instead of Blackview animation there is jsut "android" text with default animation.
At least I managed to delete boot music.
Android apps for changing boot logos don't work too.
Please, I need your advice on this.
pfavayi
Re: Can't make custom boot logo works
Mon Aug 07, 2017 5:26 pm
If all you want to do is change the boot logo , then do this.
First install twrp 3.1.1-0 through sp flashtool .
Twrp 3.1.1-0 has option to img files (as well as zip files of course). So load your img file to your your phone and install it from there with twrp.
Worked for me.
Flashfire and flashify might do the work but you need to be rooted for you to use those apps.
Quodpipax
Wed Aug 09, 2017 6:04 pm
Worked for me.
Thanks man, that really works! :)
