Bernie_W
Lineageos ???
Mon Jul 31, 2017 12:48 am
Re: Lineageos ???
Mon Jul 31, 2017 6:14 am
They are not official roms, there is someone who made these.
d8smt
Re: Lineageos ???
Mon Jul 31, 2017 8:40 am
But in the absence of any comment or support from BV on their 7.x future ROM support (or even 6.x support), it may be worth a try.
ocultos
Re: Lineageos ???
Mon Jul 31, 2017 4:37 pm
Bernie_W wrote:
Is this real?
Sadly not even unofficial roms. Downloaded the Lineage OS 14.1, and while it indeed seems to be Lineage OS 14.1, it's for the Samsung Galaxy S5. I'm guessing that's the story for the rest as well. Notice how all were posted in the end of May, weeks before Blackview even released nougat for the P2.
Bernie_W
Re: Lineageos ???
Mon Jul 31, 2017 6:04 pm
Yes, because I think for P2 there is no Kernel yet for Lineageos and without sources very difficult to port Lineageos to P2.
Better to wait, maybe there is an update to 7.1.2 coming :roll:
pfavayi
Re: Lineageos ???
Thu Aug 03, 2017 3:21 pm
And did you try ?
And if so , which one ?
pfavayi
Re: Lineageos ???
Thu Aug 03, 2017 3:23 pm
ocultos wrote:
Bernie_W wrote:
Is this real?
How could you tell the rom was for Samsung Galaxy S5 ? what did you see when you unzipped it ?
pfavayi
Re: Lineageos ???
Thu Aug 03, 2017 3:29 pm
The only true source for custom roms is xda developers ...
They will produce roms for the BVP2 in time , just keep watching ...
ocultos
Re: Lineageos ???
Thu Aug 03, 2017 3:47 pm
Check the build.prop file in the system folder. The ROM is for a model called klte, and a quick Google search says klte is Samsung's internal designation for the S5.
pfavayi
Re: Lineageos ???
Mon Aug 07, 2017 5:55 pm
Thanks for the info mate. I was always taking at face value what the room said it was.
Someone can easily brick their phone with this fake Russian room.
