The Master
Downgrade from Android 7 to 6
Sun Jul 30, 2017 5:53 pm
Hi and thanks for support.
It's clear that BV6000 with Android 7 it's a wrong choice, cause tons of problems that everyone knows.
So, please, can you provide the exact guide to downgrade it to the latest Android 6 versione?
Thanks again in advance
Re: Downgrade from Android 7 to 6
Tue Aug 01, 2017 3:25 pm
1) For me the latest Android 7 ROM is working stable if you make a factory reset after the update!
2) Just use the flashing tutorial and flash an android 6 ROM
The Master
Wed Aug 02, 2017 9:59 am
I've already installed latest 7 ROM but I've same old problems, better downgrade.
Wich kind of ROM I've to use? I see a lot of it
Tnx again for support
Tue Aug 08, 2017 3:18 pm
20161216 was the latest A6 ROM
exander
Wed Aug 09, 2017 4:28 pm
What problems? I have been using 7 from 2016 without any problems.
