TomazicM
Problem with flash ROM BV7000_PRO_Blackview_20170712
Sun Jul 30, 2017 5:32 pm
I have problem with flashing updated ROM.
Configuration:
- Android version: 7.0
- Build: BV7000_PRO_Blackview_20170609
When I try to flash updated ROM BV7000_PRO_Blackview_20170712 as described on page viewtopic.php?f=176&t=191529, flashing starts but the I get the following error:
PMT changed for the ROM; it must be downloaded
Please select "Format All + Download"
According to instructions published on page viewtopic.php?f=176&t=141026, only "Download" must be selected. I definitely don't want to format (and loose everyting).
So what should I do?
Best regards,
Mitja
Re: Problem with flash ROM BV7000_PRO_Blackview_20170712
Mon Jul 31, 2017 5:08 pm
Hello Mitja, was your device delivered with Android 7? Then you need to use this version instead: 20170717
If it was delivered with Android 6 please post here again. In that case I have to forward your issue to our technician.
If you would choose Format All + Download for flashing you may loose your IMEI/Mac-adress.
TomazicM
Mon Jul 31, 2017 5:55 pm
Yes, it was delivered with 7.0, build BV7000_PRO_Blackview_20170609.
Your advice is to use version 20170717 to update ROM, but instructions on page viewtopic.php?f=176&t=191529 explicitly say that this update is only for devices that upgraded from 6.0 to 7.0:
BV7000_PRO_Blackview_20170717 to fix the blink screen problem
The below flash rom is only for andriod 6.0 devices and that ones that had been upgraded from android 6.0 to 7.0 by user
https://mega.nz/#!ASRyDY7J!TWJBngH3kwn6 ... opaSJJE_c0
TomazicM
Tue Aug 01, 2017 5:22 pm
So who is right: "Official ROM download links" document or blackview_admin?
- Mitja
TomazicM
Thu Aug 03, 2017 5:32 pm
Hello blackview_admin,
Can I please get answer to my question: I have BV7000 Pro with original Android 7.0 and you adviced me to use version 20170717 for update, but your official advice on Official ROM download links says this version is only for 6.0 devices and 7.0 that were upgraded from 6.0.
Can you please explain this?
- Mitja
Thu Aug 10, 2017 6:36 pm
sorry for the delay. I will ask our technician what to to.
Maybe your phone had been updated by the seller and needs the other version but I an not sure and don't want you to brick the phone..
Mon Aug 14, 2017 3:34 pm
If your problem is still unsolved please try to use the software multi port flash: http://spmdttool.com/sp-mdt-v3-1728-00
TomazicM
Wed Aug 16, 2017 8:01 pm
Thanks for the reply, but what you propose is too dangerous. Flash tool SP_MDT_v3.1728.00.00 that you propose does not have "Download only" option, but only options that include format operation: "Format and Download All", "Format all", "Firmware upgrade" and "Format bootloader".
Is there really no tool to read partition info from MTK 64bit phone? That way we could find out what is the problem and why SP_Flash_Tool_v5.1724_Win complains that PTK has changed.
Fri Aug 18, 2017 1:26 pm
Use option "Firmware upgrade".
