sulthanmina123
Voice calls 4g
Sun Jul 30, 2017 1:30 pm
i have android 6 software in my phone,recently I was update my phone in android 7, before update android6 my phone 4g network voice call also going, but now after update phone in android7 ,4g voice call not going without data connection, volte simple not come in display in android7, what can I do for that problem , how to solve this problem in my phone, can I change any setting my phone , reply me.
thank you
Re: Voice calls 4g
Tue Aug 01, 2017 9:21 am
Please first update to the latest Firmware and perform a factory reset in recovery after that.
- Press Power and Volume up together for around 10 Seconds
Please report if this solved your issue or not. If not please tell us you current firmware version.
