PatrickNL
BV7000 headphones
Sat Jul 29, 2017 9:36 pm
Anyone know where I can get earphones that fit in BV7000
ORGINAL one is broken, normal 4 pole 3.5mm won't fit in it.
But the BV jack was some it extended 4 pole.
Re: BV7000
Mon Jul 31, 2017 12:29 pm
there are several shops selling fitting headphones like this one: https://www.aliexpress.com/item/Origina ... 55711.html
PatrickNL
Re: BV7000 headphones
Sun Aug 20, 2017 11:22 am
I tried to look for it.
That link clearly says
"this product is not available anymore"
Tue Sep 12, 2017 9:05 am
Sorry, The products on that platform change quickly. I will post a new link as soon I find one. You can also contact your seller to receive a spare part for the broken earphones.
