bvbw
BV6000_blackview_20170719 (for Android 6 users)
Sat Jul 29, 2017 9:01 pm
Please,
is it possible to have more details ? Do it fix some last bugs in same time ?
McSNox
Re: BV6000_blackview_20170719
Mon Jul 31, 2017 8:36 am
Hey.
You are not mistaken with the firmware number or can be wrong topic (here about the BV6000)?
If not, where did you get such firmware?
Blackview BV6000 V01_20170708
bvbw
Mon Jul 31, 2017 8:43 am
No, it's last flashable version.
See : viewtopic.php?f=144&t=178175
McSNox
Mon Jul 31, 2017 9:14 am
Noticed
I do not understand the fineness of the translation of the description.
As I understand it is the firmware for updating from 6 to 7.
It seems to be certified by Google (the implementation of Google programs and changing the touch keys "home" and "programs").
My link does not work.
One of the members of the forum said that Blackview decided to get certification from Google. Implementing Google programs and changing the touch buttons to a newer version.
Geovanny
Mon Jul 31, 2017 11:26 pm
Good evening everyone.
This version was made available on my device via OTA.
I was before with version V01-20161025.
After the update, the version remains the same and with Android 6.0.
Changed only the kernel version.
Some google app has been installed. If you do not want to disable it, you can not uninstall it. I did not notice any big changes, but I think the 4g signal got better.
I recommend the update.
bvbw
Tue Aug 01, 2017 4:47 am
Geovanny,
What about your left button function (menu or recent apps ? )
Thanks
Tue Aug 01, 2017 9:46 am
Sorry for the confusion, I updated the ROM description: Can flash only for devices running on Android 6.0 (will stay on android 6). Added Google GMS certification.
bserg2
Sun Aug 06, 2017 2:32 pm
This OTA update change left button function from 'menu' to 'recent apps' !!!
Nothing was not said about this and it is not minor bug fixes, I am very unhappy!
I have many older programs that require a menu button.
This update broke the functionality of the touchscreen and is only restored after a factory reset.
bvbw
Mon Aug 07, 2017 5:37 am
Most apps now have menu command integrated.
But i have also some apps without menu, and for them i use this :
https://play.google.com/store/apps/deta ... menubutton
CrashProof
Mon Aug 07, 2017 7:16 am
I've updated my phone from the january 2017 version. The only annoying thing sofar is that the bottom buttons are non-responsive. It takes 2-3 pushes to get them to respond.
