ashboe
Problems with Google and Google Play Services
Sat Jul 29, 2017 3:31 pm
My Google and Google Play Services keeps crashing, many times a day. I've force stopped, cleared cache and disabled and reinsalled both apps. but keeps on doing it.
Why? How to stop it
Re: Problems with Google and Google Play Services
Wed Aug 02, 2017 11:52 am
update to the latest Firmware and perform a factory reset in recovery after that.
ashboe
Wed Aug 02, 2017 3:19 pm
I rooted, upgraded to 7.0 then disabled Google Play services and forced an upgrade - that solved it
pfavayi
Thu Aug 03, 2017 2:43 pm
With google play services disabled, how did you force an upgrage ?
Was it an upgrade of google play services ? how ?
Did you use open gapps ?
I really would like to know how you executed your solution
ashboe
Sat Aug 05, 2017 11:02 am
After upgrading to nougat I still couldn't disable Google auto text services, which was causing the problem, so I Uninstalled Google play services which put it back to factory and opened a game on the phone, that forced an update which solved the problem.
pfavayi
Mon Aug 07, 2017 6:07 pm
Thanks ....
Never thought of this before!!!
Uninstall Google play services with a system apps remover.
And the game you played required Google play services so the system downloaded it from the play store.
So how did you go about installing it as a system app ?
ashboe
Tue Aug 08, 2017 8:03 am
Didn't use a system app remover (though I do have Titanium). In Apps, force stop, disable - OS simply removes latest update to the system app removing the conflict. Even now I have stopped Google itself from updating as I don't want there to be another conflict
pfavayi
Sun Aug 20, 2017 9:29 pm
"In Apps, force stop, disable - OS simply removes latest update to the system app removing the conflict. "
The update from google play was problematic so you removed it and disallowed the system to update ...
I think the solution is incomplete and bound to produce similar or other problems because of the necissity of the system to update google play services.
I think a better solution would be to remove the update as you did and then use a system app remover and remove google play services , then download and flash through twrp the latest minimal open gapps (pico version)
Why the minimal version ?
Because many of the included apps in gapps or open gapps will cause problems , which is probably why there are problems in the first place in your case.
As I said before , disabling google play services udating is not a complete , permanent or disirable solution .
ashboe
Tue Aug 22, 2017 12:49 pm
I'm sure you are right but it's working now, and thats all that matters to me :D
