eslam
Lost imei blackview bv 7000 pro
Fri Jul 28, 2017 9:54 am
Please help lost imei After the update :?: :?: :?:
Re: Lost imei blackview bv 7000 pro
Mon Jul 31, 2017 5:19 pm
IMEI get lost when you choose format all while flashing!
Here is an IMEI repair tutorial for bv6000, I hope it will help you with bv7000pro as well.
viewtopic.php?f=142&t=128401&p=308642#p308642
Ohno
Wed Aug 16, 2017 3:58 am
I tried Tutorial of IMIE repair,
but it failed.
start SN_Write_Tool, and connect a BV7000pro.
And later, i can see " Start loop write data to nvram..."
Few second later,
it is failed, message is
"ERROR!! IMEI[0]:MetaResult = META_TIMEOUT"
What is problem ?
it is burned BV7000_PRO_20170523_release ROM.
fail_sn writer.jpg (61.8 KiB) Viewed 7179 times
1andreew1
Thu Aug 17, 2017 6:56 am
1andreew1
Thu Aug 17, 2017 5:40 pm
IMEI.pdf
Восстановление IMEI
(305.16 KiB) Downloaded 1251 times
Ohno
Fri Aug 18, 2017 2:19 am
1andreew1 wrote:
http://4pda.ru/forum/index.php?act=findpost&pid=61220724&anchor=Spoil-61220724-1
This solution is successful.
Very good.
Thank you very much, I appreciate.
Fri Aug 18, 2017 1:21 pm
Thank you for helping / feedback!
