zule
Blackview BV8000 Pro dont work cellular network and the fingerprint
Fri Jul 28, 2017 7:46 am
Hi, I bought this phone two weeks ago, And since then I've been trying to internet through the cellular network And I did not succeed.
I tried everything for what I know, Manual adjustment, Changing cards, Factory reset, update, But he does not want to work I do not know what to do anymore.
Does anyone know something, Or someone had the same problem i fixed it.
The other problem is fingerprint When I got it worked, Once unlocked five times, no,Then it will block does not work, Nothing works, Then it will not scan fingers, I do not know what that is, but I think that Software problem.
I ask for help if someone knows a solution.
Re: Blackview BV8000 Pro dont work cellular network and the fingerprint
Thu Aug 03, 2017 11:50 am
for the celular data:
1) check your apn data (settings > more >cellular networks > APN)
2) activate data conection (swipe down qick settings > tap carrier name > turn on data)
