oriental
WiFi disconnect itself without reason, GPS also not working constantly
Fri Jul 28, 2017 6:21 am
bought the phone only about a month, everything was working perfectly until the past couple of days.
out of the blue wifi started to disconnect itself during my usage, for example I'm reading or playing mobile game, suddenly no connection without a sign.
the worst is when I'm in the car using GPS to navigate direction, even the 3G mobile data and location disconnect, the navigation just paused when I'm in the middle of the traffic!!! this is horrible.i didn't update the phone or did anything at all, not expert about high tech, please help me fix this!
Re: WiFi disconnect itself without reason, GPS also not working constantly
Tue Aug 01, 2017 3:55 pm
update to the latest Firmware and perform a factory reset in recovery after that.
