Pappmann
TWRP + root
Thu Jul 27, 2017 9:16 am
4pda has found a way to root: https://4pda.ru/forum/index.php?showtopic=834817&st=0#entry63155473
Anyone tested it yet? I dont have an account there so i cant download the files :(
Aeron
Re: TWRP + root
Thu Jul 27, 2017 4:03 pm
I'm also interested and willing to try, but I don't understand russian...
Btw, currently testing a debloated and deGoogled version of 07/18 update.
tmsjaeger1
Re: TWRP + root
Sat Jul 29, 2017 1:31 pm
Can someone translate the Russian page to English?
@admin, can you give us root please? Thanks
Pappmann
Re: TWRP + root
Sat Jul 29, 2017 1:46 pm
Is the debloated version working fine? Is the Statusbar/Quicksetting original android or themed like in the original Blackview ROM?
I now have a account on 4pda.ru and i rooted my BV8000pro successfully. I enabled the multiuser mode, but there is no shortcut to switch user in statusbar. I can enable a second user but in the second profile the settings page is crashing if i want to open it and i cant go back to the main user profile :(
I uploaded TWRP 3.1.1 from jemmini and other needed files at needrom.com: https://www.needrom.com/download/bv8000pro/
Aeron
Re: TWRP + root
Sat Jul 29, 2017 9:55 pm
Not so much actually :oops: for now ;)
I don't plan to modify anything in the software itself, only to remove Google apps (a lot are far from essential) and other non-essential apps.
Sorry I won't be able to help you with multiuser, I don't use it.
jimmy02000
Re: TWRP + root
Sun Jul 30, 2017 8:42 am
Bonjour, https://yadi.sk/d/Qtb_HZys3L5a76
BROM ERROR: STATUS_DA_HASH_MISMATCH (0xC0070004)
[HINT]:
or
Prelader
Please Help
Aeron
Re: TWRP + root
Fri Aug 04, 2017 7:08 am
Just forwarding a link found in another thread, so people looking for a root solution here find it : BV8000Pro TWRP Root
tmsjaeger1
Re: TWRP + root
Mon Aug 07, 2017 9:43 am
It works fine for me, just to give some feedback
IASmirnoffe
Re: TWRP + root
Tue Aug 08, 2017 6:48 am
I'm russian, what do you need to translate?
As 4pda users tell it works.
I will try it today
Parcheval
Re: TWRP + root
Tue Aug 08, 2017 9:02 am
So no problem following this on BV6000?
Really don't need root, except for Titanium backup which requires it and seems to be the best backup app available (if anyone knows a better one with both app and app data backups without the need of root access, please comment)
