Weaving
Battery to death
Wed Jul 26, 2017 5:29 am
Hello, I have a problem with phone if I use and listen web radio on mobile app and the battery will down (with and without charging. Charging is too slow and battery will down always). If the battery is too much down phone will turn off. But if I connect to wall usb charger, it do nothing. No charging, no led light and no turn on. Is just one way to rebirth baterry, with xiaomi powerbank. After few minutes with charging of this powerbank will starts led light and start charging from 1%. Other chargers do nothing after fwe hours. The problem is at android 7, latest update. Do you have similar problem anybody? I am very scary always the baterry is death and do nothing with normal charging. Sry my english and thank you for answer
Re: Battery to death
Mon Jul 31, 2017 5:50 pm
Please update to the latest Firmware and perform a factory reset in recovery after that
- Press Power and Volume up together for around 10 Seconds
Please report if this solved your issue.
