CarlosT
Blackview BV7000 pro with flicker(blink) screen
Tue Jul 25, 2017 8:41 pm
Hi, i recent bought a Blackview BV7000 pro this year (June2017)from Gearbest and after a week use the screen flicker sometimes when i change to Camera or Photo Galery
what can i do? who should i talk to? pls help...
thanks
CarlosT
i can be reached here or by email Karlprimswitch@sapo.pt or skype KarlPrimswitch (pspe1000)
Re: Blackview BV7000 pro with flicker(blink) screen
Mon Jul 31, 2017 6:02 pm
Please update to the latest Firmware and perform a factory reset in recovery after that
- Press Power and Volume up together for around 10 Seconds
Please report if this solved your issue.
redbeat
Fri Aug 25, 2017 3:10 pm
i was update to latest firmware, this solve problem flickering on 3 weeks. And now screen flickering again.
pls help...
Stroy
Sat Aug 26, 2017 12:48 pm
pls help...
me too btother,
@blackview_admin please help and advice
Stroy
Wed Aug 30, 2017 10:13 am
Stroy wrote:
pls help...
me too brother,
@blackview_admin please fix the problem via wireless update, i'am very sad with this problem, please fix the problem @blackview_admin
Stroy
Thu Sep 07, 2017 3:24 am
@blackview_admin Please respond my problem, I have been very patient about the problem , whether like this blackview serving their customers. please give me solution and fix the problem.
Tue Sep 12, 2017 3:24 pm
I will report this as new issue. Please try if a wipe/factory reset help.
Stroy
Wed Sep 13, 2017 2:55 am
I've tried it and the result is worse than ever, please help and give me solution.
I think blackview is a professional company. definitely have a solution on this issue
Stroy
Sat Sep 16, 2017 7:31 pm
What the new solution for my problem ? @blackview_admin
What you have target for fix the problem ? Please give me solution for this problem
Thu Sep 21, 2017 1:45 pm
Sorry, if flashing to the latest firmware* + factory reset does not help contact your seller for exchange the device.
*If your Phone was original delivered with android 6 it's 20170717
If your Phone was original delivered with android 7 it's 20170712
