refealewis
Loosing all sound during call.
Mon Jul 24, 2017 7:04 pm
I purchased the Bv8000 late last week. Overall the phone works well. The main issue i am having with it is that during a phone call at random times i loose all audio on both ends. If i end the call and make a new call the audio comes back. The other problem is that while streaming music over Bluetooth to a Bluetooth speaker its skips like a CD with scratch. I have run both updates phone says it is all up to date. Still having these issues. I am in canada.
Re: Loosing all sound during call.
Thu Jul 27, 2017 2:17 pm
Thanks for your feedback. I will reply again as soon I know a solution.
zimzia
Thu Jul 27, 2017 6:00 pm
I have the same problem
Fri Jul 28, 2017 9:27 am
Do us have the issue with firmware 20170718 now?
zimzia
Fri Jul 28, 2017 1:26 pm
Yes I have and before too
Thu Aug 03, 2017 11:39 am
please try this:
