zimzia
New version of android Corrects errors ?
Fri Jul 21, 2017 1:44 pm
I have bv8000 Pro 1 day, compilation android is 20170613, I just noticed automatic brightness did not work (sensork work well in test mode *#87#), notification LED too dark and the first desktop replaces places with the last display, translate system 50/50.
bluetooth ok
fingerprint OK
when connection to computer see BV8000 PRO
Wifi wor but very small signal max 3m from router, bv6000 Had a better range, much better.
Update what fixes?
Best Regards
Zeerch
Re: New version of android Corrects errors ?
Sat Jul 22, 2017 1:06 am
On the display / Adaptive brightness when switched on turn down the brightness level to a lower level.
