poijoin
Bv7000 ils it working now with Telus Canada???
Fri Jul 21, 2017 1:11 pm
I'm about to buy a bv7000, but I've read that phone is not compatible with Telus in Canada and will not be !
poijoin
Re: Bv7000 ils it working now with Telus Canada???
Sat Jul 29, 2017 10:51 pm
Can someone help me please ???
Iwould like to know if this phone is compatible with bell or Telus in Canada, I've read fido and roger work but those are not my provider.
If bv7000 doesn't work is the bv8000 can work on telus networks
Thank you to help me!
Mon Jul 31, 2017 12:24 pm
Please check the frequencies your provider is using.
This are the frequencies of BV7000:
2G: GSM 850 / 900 / 1800 / 1900
3G: WCDMA 900 / 2100
3G: TDSCDMA 1900 /2100
4G: LTE 800 / 900 / 1800 / 2100 / 2600
This are the frequencies of BV7000 Pro:
This are the frequencies of BV8000 Pro:
3G: WCDMA 850 /900 /1700 /1900 /2100
4G: LTE 700 /800 /850 /1700 /1800 /1900 / 2100 / 2600
4G: TDD 1900 /2300 /2600 /2600
4G: CDMA 2000
