h0w4rd
20170708 - menu and home buttons - why?
Fri Jul 21, 2017 5:27 am
This is how it should be :
Menu button - short press - context menu
Menu button - long press - google assistant
Home button - short press - home launcher
Home button - long press - app switching
Why have you changed it?
Re: 20170708 - menu and home buttons - why?
Fri Jul 21, 2017 8:07 am
We will report your issue and fix this problem soon.
bvbw
Fri Jul 21, 2017 9:11 am
Good to ear that !
If in the same time it should be possible to fix the problem GPS time 1 hour wrong ... (not difficult for normal devs)
h0w4rd
Fri Jul 21, 2017 12:36 pm
Thank you in advance.
Another suggestion - is it possible to add an option to Settings so we could configure those 3 buttons?
bvbw
Fri Jul 21, 2017 2:51 pm
It's difficult for them to do simple things ... So please, don't ask them nothing more ... ;)
h0w4rd
Fri Jul 21, 2017 8:36 pm
Don't be so pessimistic :)
I wish I knew why they changed the buttons behavior.
Give us option to configure them would be amazing :) but I don't expect a miracle :)
tomithyom
Fri Jul 21, 2017 11:57 pm
Does this new update '20170708', fix the Capacitive touch button sensitivity on all BV6000 phones?
I want to install it but not if it doesn't fix the touch button issue that myself and everybody complains about.
bvbw
Sat Jul 22, 2017 1:35 am
Seems better, but because now no menu button, I've rolled back to previous version. Waiting for the next version, i hope soon ...
h0w4rd
Sat Jul 22, 2017 6:55 am
For me it was ok in 20170507.
But don't rely on it, not all BV6000 are the same.
