toembal
problem update ROM BV7000 Pro 20170717
Fri Jul 21, 2017 12:53 am
i already download this ROM,
i try to update by local update & Flash method
in local update method, ROM cannot read (i place ROM in internal storage)
in flash update method, stopped at scatter read process by SP Flash Tool
am i made a mistake maybe?
toembal
Re: problem update ROM BV7000 Pro 20170717
Fri Jul 21, 2017 12:54 am
today i try to update by OTA method, and still not available
Fri Jul 21, 2017 6:08 am
Did you follow the flash manual?
flashing-BV7000pro.pdf
(364.59 KiB) Downloaded 1874 times
flashing-BV7000pro_v3 for win10.pdf
(372.78 KiB) Downloaded 977 times
toembal
Fri Jul 21, 2017 6:49 am
i already follow instruction flash method and work when update from marshmallow to version 20170622
i try with same step to update with last ROM, not work
matgr75
Fri Jul 21, 2017 4:41 pm
it's true. Scatter file is corrupted.
lucasportela
Fri Jul 21, 2017 4:56 pm
I tried the local update, nothing happens. I tried the original archive and it doesn't work. Then i converted the archive to ZIP and tried again, the phone recognized the archive but didn't work too. My screen was totally black, i waiting for something to happen but nothing happened. Then i needed to turn it on pressing the power button and the volume button. The phone is on, but still the original ROM.
Please, asnwer us.
Bluescorpie
Sun Jul 23, 2017 12:00 am
Rename the folder name, delete chinesse alphabet,
Your system not recognice that alphabet
Mon Jul 24, 2017 9:58 am
Thank you for your help!
toembal
Tue Jul 25, 2017 2:32 am
after waiting 10 minutes problem still occure:
Tue Jul 25, 2017 11:49 am
This is an other issue. I know this Error Code from a computer with outdated drivers. Please try to replace/update the drivers for this phone-connection on your computer to solve this.
