cientistagyn
White color of the screen has a yellow tint
Thu Jul 20, 2017 7:21 pm
I bought two bv8000 pro, but one of them has a much more yellow tint in white color. Both with the same configuration in display, miravision and all settings, even both after factory reset the difference is big. How can i fix it ? Tried everything in configurations but the difference still there.
Please help me to fix. Thank you !
* I took a shot but live the difference is much bigger
Zeerch
Re: White color of the screen has a yellow tint
Fri Jul 21, 2017 12:16 am
I would send back the yellowish . That is a sign of bad component in the screen board. I would not do anything more just to protect the warranty.
dimuthume
Sun Jul 23, 2017 6:17 am
it can be due to changing the screan colour or the reading mode in settings
rgnz
Mon Jul 24, 2017 2:22 am
It looks a bit like you have Blue Light Defender turned on under Settings/Display/Miravision
Thu Jul 27, 2017 2:26 pm
thanks for helping here
