burg3r
[SOLVED] Update available
Thu Jul 20, 2017 12:33 pm
Hey guys, today my bv8000 pro told me to do a update of 87mb. I agreed and after that I checked with CPU Z my cores. It seems that the second cluster is going down to 1ghz if it can. After that is says it need another update of 119mb. I agreed too. The second cluster is on maximum all the time. But my Batterie life is amazing now. 10% in 6hours. And it seems that the camera is faster now on autofokus. I get no failure after the update. Great work and do more so.
Best regards.
PS I'm now on version
BV8000Pro-Blackview-V0.1_20170718_20170718-1901
Re: Update available
Thu Jul 27, 2017 12:07 pm
Thank you for your kind feedback!
tysken
Thu Jul 27, 2017 7:33 pm
I have the same version, but i found the fingerprint is not so exactly anymore.When i make a video, the colors are very high, till exempel the grass in front of the house is very green, but it´s only darkgreen.The compass is still turning crazy sometimes and work only with high precision, in batterysafe i get no signal.
My battery keep for a day, while using mobildata and bluetooth.In Battery it says the most is the display, that needs battery.But i have on automatic.
Otherwise i am very happy with, even i get a new display from Alston for my BV6000.The 8000 is more comfortable in my job, only with mobiledata i have sometimes no connection.
And often it hang itselfs, so i must restart.Have you not this problems?
Greetings Mathias from Sweden.
Thu Aug 03, 2017 8:57 am
- Fingerprint: can you add more fingerprints of the same finger?
- Video: Are the colors only wrong on the phone or also on PC/other devices?
- I don't understand this: in batterysafe i get no signal
- hang itselfs: a Firmware reset might help*
* wipe data/factory reset in recovery (this will delete your data/settings):
tysken
Fri Aug 11, 2017 5:02 pm
1. Yes i can add more fingerprints, actually i have 5.But sometimes it dissapear and i get it back when i restart.It shows "phone enrcypted, but i can´t see the option about fingerprints.But when i restart, they are available again.
2.Okay , on the computer it looks normal.
3.When i go to location, you can choose in Mode "high accuracy", battery saving and "device only".When i switch to battery saving, my gps is not working, only when i switch to High accuracy.
I found out, that the BV 8000 Pro "very often" restarts by itselfs (doesn´t matter when connected to Wifi or mobil data).And then i have no fingerprint option.When i restart i get it back, but the phone unlock after a long time (about 5 to ten seconds, until i can make a choose on the screen.
Hope this helps you by analyses.I will make a factory reset, when i read here a stable version.Or do you think it will be a solution?I read from others, that it doesn´t helps.Gimme your recommendation please.Thanks
off topic: i still wish you can made a adapter so i can connect it to aux like the adapter from USB-c to micro.
my version is still V0.1_20170718_20170718-1901
Greetings from Sweden.
Mathias
tysken
Sun Aug 13, 2017 12:57 pm
@admin:
i made a factory reset, and the reboot no longer happens.With Bluetooth i had never problems.Outside pictures with camera are okay, but in bad light very blurry.NFC works from the beginning even with earlier rom´s.
The fingerprint not work properly , often i can´t open the phone , because no reaction with fingerprint.
Don´t understand me wrong, but a factory reset is not a good solution.You may understand, it cost much time to install all apps again.And specially apps , they need separate settings.
Otherwise a great phone, i am still glad with the speed , the handling too.
Only battery is not keeping two days.The automatic brightness not working properly, and i think this costs battery.
Then i have problems with sending Multi media messages.Even with the BV 6000 i can´t send MMS.Did you have a recommendation with the settings?
I checked my operators setting and all are the same.But if i send a picture by sms, i get always a error.
Mon Aug 14, 2017 1:59 am
tysken wrote:
@admin:
if you perform a "dirty" flash which the OTA and local update do, then you're not getting the safest experience as all it does is overwrite the system partition, this can cause bugs and other issues
if you do a "clean" flash then its better as that's what the update was really made for, this makes it so there's so duplicate files by mistake
