J-M-L
[SOLVED] Headset problem
Wed Jul 19, 2017 3:51 am
After one week of normal use, it seems like i got an issue with the headphone jack.
Got the headphone symbol on the screen without having any headphone plugged into.
Is there a way to disable that, as I can't use the phone for telephone calls the normal way.
To do a call I have to use the speaker/mic or plug in the headset.
Never had the headset plugged in before until I got the symbol on the screen and tried different ways to communicate.
Hope u got an idea to fix that.
Btw, restarting and reset didn't work either.
The headphone plug is also clean and dry
Zeerch
Re: Headset problem
Fri Jul 21, 2017 12:39 am
JML,
did you dunk this in water yet?
If you have this issue its on the main board. the only way I could see this being a issue is when you have water ingress.
just a thought.
voodoo88
Re: Headset problem
Sat Jul 29, 2017 3:27 pm
I have same problem.
Re: Headset problem
Thu Aug 03, 2017 11:22 am
Thanks for your feedback. we will study this issue.
Re: Headset problem
Fri Aug 04, 2017 10:35 am
If you are affected by this headset issue please try to update to the latest firmware and perform a factory reset after that. If that don't help please contact your seller to exchange the device. Sorry for this inconvenience. (Only) if you don't receive help by the seller please contact us with all your buying details (shop, date, order-number, ...).
shahardemos
Re: Headset problem
Fri Aug 04, 2017 11:27 am
Hi, another option (quite easy and not problematic) is to use a USB sound device. The following one supports microphone as well:
https://www.aliexpress.com/item/Vention ... 0.0.gYiEIw
You can use the small USB-C to USB cable, connect the sound USB and then connect your standard headset to it. Works without issues with standard 3.5 connector.
Neville
Re: Headset problem
Wed Oct 25, 2017 4:44 am
Did anyone find a solution to this? I have a customer with brand new phone continually showing headset icon even though headset has never been plugged in, and he can't use phone normally as device thinks headset is plugged in.
Is this a software fault?
Or is this a hardware fault?
Can I fix it by disconnecting headset socket from mainboard?
bigbang63
Re: Headset problem
Thu Oct 26, 2017 8:58 am
I had the same problem, after wash water and i reboot the phone, everuthing was ok after, but before you must dry the hole for the jack with a piece of tissue.
Quoquallse
Re: Headset problem
Thu Oct 26, 2017 7:38 pm
i had the same problem with my headsets
Hope in the Lord
Re: Headset problem
Sun Oct 29, 2017 10:17 am
I havent quite got that problem but my headset will only work through one speak very occasionally If get in right position halfway in. Not good
