matgr75
Battery drain
Wed Jul 19, 2017 2:25 am
Anyone noticed Battery drain on bv8000? CPU-z shows that 4 cores are on maximum all the time. Any solution?
burg3r
Re: Battery drain
Wed Jul 19, 2017 4:34 am
Me too. The first cluster goes down to 1 GHz but the second is on maximum all the time
paulies
Re: Battery drain
Wed Jul 19, 2017 6:45 am
I have the same problem to phone is always slightly warm to the touch.
Im sure (probably not)blackview will do a swift quick firmware update to solve all the issues there flagship phone has.
Personally I think blackview are more interested in making new phones than fixing the new and old.
Thanks Paul
Zeerch
Re: Battery drain
Fri Jul 21, 2017 12:37 am
Paul,
You still facing this problem? I dont seem to have this problem. maybe a app that is using alot of data?
Users browsing this forum: No registered users and 14 guests
