Official ROM download links
Tue Jul 18, 2017 6:32 am
In this thread we are publishing the download links of official ROM releases for BV7000 (but not BV7000Pro!).
Download: If you have trouble using the mega.nz-website you can try software like JDownloader 2 for download.
Backup: We suggest to save a backup of your data before updating to a new version.
Update: Update can be make Over the Air (OTA) and by local file update (both step by step) or fy flashing over a PC (direct to any version).
- OTA-Update: Go to "Settings>About phone>Wireless Update>Check for updates. ALL public versions will be published by OTA Update, anyway this method can sometimes be not available for some devices.
- Local Update: Save ZIP-File to your phone storage and select it at "Settings>About phone>Wireless Update>...-Menu>Local updates".
- Flashing: Here is a Tutorial for flashing ROMs. Please be sure to understand everything. Making mistakes while flashing could brick your device.
BV7000_Blackview_20171102 optimize camera and fingerprint compability
https://mega.nz/#!xPwkWCBY!WhfR7W4QmiD3 ... t1caA7q-7E
BV7000_Blackview_20170412-3 to delete the hotknot, fix the bottom record does not show on the phone list, to fix the problem that the screen does not automatically die when the flashlight menu exits
https://mega.nz/#!cORkCQ6R!mNtFvU9EtzG_ ... OuC6LK2V3Y
BV7000_Blackview_20170412-2 to take out the hotknot and optimize the screen function.
https://mega.nz/#!EfZzSJyK!T-V24pJ-caAe ... U9cSEbR1P8
BV7000_Blackview_20170612
https://mega.nz/#!xXABRDKQ!w-oRvNY1dty- ... bnLj5x45Mk
https://mega.nz/#!kCYTnYqQ!dRrCmsDC5dqd ... mM-GPZPSNQ
