Llery
Sim 2 doesn't work
Tue Jul 18, 2017 2:53 am
Hi, I need your help. I have de blackview bv 6000S end when I put a sim card in the SLOT 2, it doesn't work. It says SIM 2: EMPTY...
I tried with diferent sim cards and none work, not even the one that works in slot 1...
I need your help please because I bought the phone to use it with sim cards.
Thanks.
Re: Sim 2 doesn't work
Tue Jul 18, 2017 6:23 am
Please contact the online re-seller to get replacement.
Llery
Tue Jul 18, 2017 2:35 pm
Thanks, but the reseller told me that the period changes expired. Anyway, it took me 2 and half month aprox. waiting to get the cellphone. So I would have to consider about 5 month to get a another one? (2 1/2 month to send ,2 1/2 to get)...and I would have to buy another while I wait... Can you send me another cellphone, and when I receive it I'll send you my cellphone back. At least this work with one sim card, so I won't have to buy another while I wait.
Help please, I don't want to lose my money.
Thanks
limegreendefender
Fri Aug 04, 2017 8:09 pm
My 2nd SIM started working when I updated from 20161025 to 20161216 (Android 7)
Wed Sep 27, 2017 11:43 am
thanks for your feedback
