rgnz
No LTE connection
Tue Jul 18, 2017 1:52 am
I have a problem in that I get no LTE/4G connectivity.
I am on Vodafone New Zealand.
Their frequencies are:
2G - 900/ 1800 MHz GSM, GPRS
3G - 900/ 2100 MHz UMTS, HSPA, HSPA+, DC-HSPA+
4G - 1800 MHz LTE, 2600 MHz, and 700 MHz
I have set Preferred network typ to 4G/4G/2G (auto) but only ever connect to 3G UMTS.
Thank you
rgnz
Re: No LTE connection
Thu Jul 20, 2017 12:15 am
Just an update. Two phones laid side by side on a table Galaxy S5 connects to LTE easily. BV8000 Pro only connects to UMTS.
The Blackview will only connect to LTE if it's almost sitting under a cell tower. So it's a problem with reception in the phone, not the frequencies.
Zeerch
Fri Jul 21, 2017 12:23 am
rgnz,
I would run the latest update and see if it fixes that issue, there is alot of changes in the latest update but no one knows the change log, as its not published, maybe its Top Secret. see if that helps you.
some updates they have band correction in the frequency hop sequence.
rgnz
Sat Jul 22, 2017 5:48 am
Thank you for your reply.
System says it is up to date.
Current version is BV8000Pro-Blackview-V0.1_20170718_20170718-1901
Checked it again today but still has the same issue.
rgnz
Wed Jul 26, 2017 10:53 pm
Update... It appears it's a software issue with the BV8000.
I was 100m from a cell tower and the phone showed 4G and showed full signal strength... until I picked up the phone and tried to use it.
It immediately switched to 3G UMTS ... stayed on UMTS and would not switch back to LTE
Hello Blackview is any one listening?
How do you get technical support for Blackview phones?
Is this the only place to get it?
Thu Jul 27, 2017 12:21 pm
Thanks for your detailed feedback. I will report this to our technicans.
