grAwp
Ear speaker not work properly
Mon Jul 17, 2017 6:33 pm
Dear Blackview,
on my BV6000 ear speaker after time do not work properly. Can you give me some advice how to change it ? I can order new ear speaker but i dont have the silicone. Can i buy it somewhere ? I want the phone with IP 68 (waterproof) and i must have the white silicone to put on the ear speaker. Thank you for your help.
Re: Ear speaker not work properly
Tue Jul 18, 2017 9:26 am
You can use every strong waterproof silicone or glue. Should be available in every hardware store.
grAwp
Tue Jul 18, 2017 11:20 am
Which waterproof silicone you exactly use on gluing ? Can you give me a link of some type of that silicone or glue ?
Thank you
