Seanboy2017
[SOLVED] Help
Mon Jul 17, 2017 3:42 pm
The bottoms on my blackview. Are really loud. When I shake the phone.. is this a simple fix?? The bottom botton on left side of the phone does not work when I push it I get error. Says please install ptt..
The notification light is very dim and. Blue tooth has almost no volume... Please help me blackview
Re: Help
Wed Jul 19, 2017 12:42 pm
To use the button for ppt (=push to talk) please install an app like zello.
https://play.google.com/store/apps/deta ... .loudtalks
Zeerch
Re: Help
Fri Jul 21, 2017 1:02 am
Did you ever fix this problem?
Re: Help
Thu Jul 27, 2017 12:03 pm
@Zeerch I don't understand which of the issues you are talking about.
Users browsing this forum: Google Adsense [Bot] and 1 guest
