transpose
Need a custom recovery.img 20170622
Mon Jul 17, 2017 3:26 pm
wanting to root this phone, haven't been able to get a custom recovery that works for it so far.
Version: 20170622
there seems to be one on the Russian 4pda website but unable to speak Russian so cannot do the captcha code.
or if there is any other way to root easily please let me know.
okmafrican
Re: Need a custom recovery.img 20170622
Fri Aug 11, 2017 11:50 am
good day, ive a blackview bv7000pro forgot password and want to factory reset it
Mon Aug 14, 2017 7:05 pm
- Select factory reset
