Re: front camera is problematic no keys are available
Sat May 07, 2016 8:29 am
If the rear camera can work properly ?
if yes , you can try a factory reset to see if the problem can be solved.
Best regards,
Admin
suzieapedo
Sun Aug 06, 2017 12:34 pm
My back camera wont work.
Front camera is always upside down.
Big problem from first month
