Bluescorpie
Share Your Rom version and antutu score
Mon Jul 17, 2017 9:02 am
9 month old of bv6000, Rom Ver: 20170414 with 49 apk installed, Antutu score is 47329
The_Saint
Re: Share Your Rom version and antutu score
Mon Jul 17, 2017 10:04 am
4 month old, V01_20170708, 70 apps installed, Antutu score is 48861
97gérard216
Mon Jul 17, 2017 11:18 am
12 month old, V01_20170708, 58 apps installed, Antutu score is 49978
Priyanga
Mon Jul 17, 2017 3:43 pm
2 months 2017-05-17 44531
Bluescorpie
Tue Jul 18, 2017 1:30 am
Great Almost 50000
Any lag or bug happened with 20170708?
why i could not reach that point?
Is there any step that i missed when flashing?
97gérard216
Tue Jul 18, 2017 11:56 am
"Bluescorpie » Mon Jul 17, 2017 9:30 pm
"Great Almost 50000
Is there any step that i missed when flashing?"
Purchase 20160711, serial number: GURCHMCULNAZ5NN4P. After updating OTA V01_20170708, I save my personal files before that. Then, i did a factory reset (all data and setting will be lost through this). I always do a factory reset regardless of the update.
- Press Power and then Volume (+) about 10 seconds
- When Blackview appears, release Power
- When open Androïd is displayed release volume (+)
- Then Press Power and then Volume (+)
- Use the Volume (-) key to select "Wipe data / factory reset"
- Use the Volume (-) key to select "Yes - delete all user data"
- After the factory reset select "Reboot system now", confirm with Power supply.
Alain 76
Tue Jul 18, 2017 12:49 pm
12 month old, V01_20170708, 99 apps installed, Antutu score is 45874.
But I do not reset the factory, too much time lost to reconfigure everything.
Anyway, it's a year old, so I'll soon change it.
But before changing it, this will help me take pictures and movies of my vacation in the sea, pools and slides for a week.
I always close the loudspeaker with duct tape when I put it in water, just for security.
Pirri91
Tue Jul 18, 2017 4:04 pm
1 year old, V01_20161025, 52 apps installed, Antutu score is 48178
Eee8
Tue Jul 18, 2017 6:24 pm
Bv6000 ver: 20170321 score: 50323
Eee8
Tue Jul 18, 2017 8:07 pm
Bv6000 ver:20170321 score 50419
