Pedro
your system was damaged wireless update is disabled
Fri May 06, 2016 4:58 pm
I hev this problem:
In WIRELLES UPDATE
Re: your system was damaged wireless update is disabled
Sat May 07, 2016 7:34 am
Pedro wrote:
I hev this problem:
In WIRELLES UPDATE
Hi ,
On May 9th, BV5000 OTA upgrade to Android Marshmallow will be available,
you can check then if this new Android Marshmallow can solve the problem or not.
Best regards,
Admin
SnuffThePunkz
Sun May 08, 2016 4:46 pm
I got that error, it was due to my root though. You in the root party?
ScalSaver
Sun May 08, 2016 6:14 pm
I have the same firmware version than OP. Rooted with Kingroot, unrooted afterwards. Same error after unroot.
Help ?
yairsal
Mon May 09, 2016 11:35 am
Hi
I have the same problme in BV2000!
waiting for help....
steirx
Mon May 09, 2016 12:13 pm
For what it's worth - here is how I updated my phone with the manually downloaded ROM. In my case, there was no need to root the phone, etc.
1) Simply download the ROM zip file an transfer to your SD card (internal or external)
2) Go to Settings
3) Click on About phone
4) Click on wireless update
5) Click on three vertical dots in the right hand top corner
6) Select Local updates
7) select SD card / folder / ZIP file that holds the ROM update that you have downloaded (manually)
And follow the steps to upgrade / update your ROM.
Hope this works for you!?
