WSGolem
Bluetooth connection problem / Front camera mirrored
Sun Jul 16, 2017 4:39 pm
Hello! I live in germany and use 1 BV6000S since 1 year and a BV6000 since a half year. BV6000 on Android 7 and BV6000S on Android 6.
I am looking for solutions for the following problems:
On both devices the image of the front camera is mirrored. Main camera works fine. I could not find a setting that changes that. Factory Reset
has no effect. Any ideas?
On both devices i cant connect all my bluetooth-devices with the phone after its reboot. It means, for the bluetooth-Device the Phone seems to be unknown / new device after its reboot. I have to reconnect / recouple the bluetooth-device. Car Audio, Headphones, Speaker, same problem. F.e. in Car Audio a second "BV6000" appears in the list, after a restart a third etc. Other Phones works fine.
It affects both BV-devices. Does anyone have an idea what I can do about it?
The already mentioned problem with the freezing launcher3 I solved by installing another launcher. It affects only the Android 7-Device.
WSGolem
Re: Bluetooth connection problem / Front camera mirrored
Tue Aug 22, 2017 7:34 am
No one else has a mirrored frontcamera? I can not believe that... Other mobile phones have the problem synonymous, but also an option to rotate.
Fri Sep 08, 2017 4:59 pm
You could use apps like open camera with an option to mirror the picture.
WSGolem
Tue Mar 20, 2018 3:02 pm
I found out that the device has a different MAC address after each reboot. That is the reason why i have to re-pair it after every reboot in the WLAN and Bluetooth. Does anyone else have the problem or can I tell you how to solve it?
Sun Apr 22, 2018 10:26 am
i will report that to the tech team! ;)
