yairopro
[SOLVED] Blackview 8000 pro + Waze = CRASH
Sat Jul 15, 2017 10:23 pm
Hello
Waze always crashes when I launch it on my Blackview 8000 pro.
I uninstall-reinstall many times, but it doesn't help.
elrik1090
Re: Blackview 8000 pro + Waze = CRASH
Wed Jul 19, 2017 2:58 pm
I got the same problem. Very bad, i use it all day long for my work... :-(
Patrys4
Thu Jul 20, 2017 8:12 am
Does anyone already have a solution? Just like me, you can not start WAZE.
Thu Jul 20, 2017 10:27 am
We have reported this, will be back soon.
Zeerch
Fri Jul 21, 2017 12:35 am
I have reached out to Waze about this issue as well. they are working on a update to hopefully fix our problem. They never heard of Blackview and dont know anything about. I offered to send them a bv8000 pro to test it. I know Blackview wont do it, but I will on a personal level. I wont let them have it, its more of a loaner.
If it helps the rest of us, I have one ready to be sent DHL to their team.
I will get an answer today.
Hang in there.
dastillero
Wed Jul 26, 2017 8:02 am
Hang in there.
Hi Zeerch,
do you have an update on this issue?. As I'm using Waze almost everyday to avoid our infamous traffic jams, this is impeding me using my new bv8000 pro :)
Thank you very much!
Thu Jul 27, 2017 1:57 pm
Does this also happen with the latest firmware? viewtopic.php?f=192&t=213272
dastillero
Thu Jul 27, 2017 2:42 pm
Yes, it happens with that firmware version too. At least for me.
Thanks
Patrys4
Thu Jul 27, 2017 5:31 pm
Software BV8000Pro_blackview_20170718 nothing has changed! Next you can not start WAZE
Fri Jul 28, 2017 9:19 am
Thanks for the feedback.
I will reply as soon I know a solution.
