Official ROM download links (only for MT6737T)
Sat Jul 15, 2017 1:39 am
In this thread we are publishing the download links of official ROM releases for BV6000S.
Download: If you have trouble using the mega.nz-website you can try software like JDownloader 2 for download.
Backup: We suggest to save a backup of your data before updating to a new version.
Update: Update can be make Over the Air (OTA) and by local file update (both step by step) or fy flashing over a PC (direct to any version).
- OTA-Update: Go to "Settings>About phone>Wireless Update>Check for updates. ALL public versions will be published by OTA Update, anyway this method can sometimes be not available for some devices.
- Local Update: Save ZIP-File to your phone storage and select it at "Settings>About phone>Wireless Update>...-Menu>Local updates".
- Flashing: Here you find a Tutorial for flashing ROMs. Please be sure to understand everything. Making mistakes while flashing could brick your device.
BV6000s_Blackview_20180314 to double click to open the camera and to let whatsapp record videos
https://mega.nz/#!eCIBCY6D!DfnspGKWuVLA ... gLfQoqbOuQ
BV6000s_Blackview_20180104 to optimize the device
https://mega.nz/#!RWIkjLaA!yY2_cwJhvlpU ... KRn-YYD3aU
BV6000s_Blackview_20170930(for MT6737T) to fix the screen whitening problem
https://mega.nz/#!0bg2FRaC!KBkhh4-5GFCL ... dx06fyRrQQ
BV6000s_Blackview_20170322 to fix the touch screen problem.
https://mega.nz/#!YH4A1DrD!dzm5itzL5wfz ... yuYYwGrDsE
(only for MT6737T)
BV6000s_Blackview_20170717 https://mega.nz/#!lf42lKqA!Rx-ve-Y0LKbg ... HYN7UKUtcc
Google certified, based on Android 6.0 and upgrade from 6.0 to 7.0. After this flash the google apps can be working normally.
BV6000s_Blackview_20170711 https://mega.nz/#!QehjDTCZ!QppiYsTrPrCQ ... F9a1Rb8vjc
Google certified. Based on Android 7.0
Re: ROMs of BV6000s download links
Fri Jul 21, 2017 3:35 am
If you upgraded by OTA and still can not use the google apps, please follow the below steps to fix the problem.
step 1
step 3.jpg (6.12 KiB) Viewed 27248 times
step2
step 2.jpg (6.68 KiB) Viewed 27248 times
step 3
step 1.jpg (6.91 KiB) Viewed 27248 times
step 4
step 4.jpg (7.38 KiB) Viewed 27248 times
