Can someone from Blackview tell me why after the last update, 14/7/17 it arrived that I have 5 unwanted apps that I can't remove.
Google Play Music, Google Play Movies & Tv, Hangouts, Photos and Drive? Sure I can disable them which I have but why clutter my phone with them in the first place.
I already have a music app on my phone pre-installed as well as well as gallery and I sure in hell don't need any of the others you cluttered my phone with either, don't you think if I wanted crap like that I would have downloaded it myself from Google Play Store??
All the update said before I downloaded and updated it was bug fixes and if I had of known it was all that crap and I would not be able to uninstall them then I would have not of downloaded the update. Is that why it only said bug fixes so that Blackview could deceive people in to installing it??
One of the good things about this phone is thaty it was not cluttered with bloat and just through one lousy update Blackview managed to make it like every other crappy phone out there.
If it wasn't for the fact my phone say BV6000 on it I might be mistaken in thinking that it is a f**kn Google Nexus phone, any fixes out there for this underhanded BS from Blackview????
