dabomb
Serial Number, Compass, Roaming Issues
Mon Dec 28, 2015 2:54 pm
I got a BV5000 for christmas. I had some time during holidays to update and test it and there are several issues I'm not glad for:
1.) First of all the compass is not working. Is there one in the phone? Is it just a software problem?
2.) When I go into the Network Settings there are only Swedish, Danish and Norwegian Carrier in the preference. The PLMN can't be added manually. I have to use it on Germany under Roaming Conditions. Please fix it in the next update.
3.) The Serial Number of the device is 0123456789ABCDEF. Some Apps use this number to verify the user. Please show me a way to change the number.
4.) Is there a way to install the "Xposed"-Framework?
Hopefully someone can help me. It seems to be a great Outdoor Phone.
Thanks
Fred
Re: Serial Number, Compass, Roaming Issues
Tue Dec 29, 2015 6:06 am
For Compass , it do not suppprt.
For network carrier , i will pass your feedback to the one responsible for it .
Best regards,
Admin
