ALAIN_F
[SOLVED] USB connexion
Thu Jul 13, 2017 11:33 am
Dear
I can't connect my BV8000 to my PC in Windows 7
Where I can find USB driver for my BV8000
Best regards
Re: USB connexion
Thu Jul 13, 2017 12:07 pm
This should work in Windows without download external driver.
If they don't get installed correct (yellow ! in device manager) try this:
1. Right-click on the device in the device manager: "Update driver software ..."
2. search for driver software on the computer.
3. Select from a list of device drivers on the computer.
IMPORTANT: Do not specify a path here! > Select from list of known devices.
4. Select the MTP USB device.
Note: Depending on the device, it may be necessary to remove the "Show compatible hardware" checkbox.
Now the smartphone should be recognized.
ALAIN_F
Re: USB connexion
Thu Jul 13, 2017 2:50 pm
Dear
I connected the BV8000 to another computer with Win7 Pro and the connection is OK
Best Regards
Zeerch
Re: USB connexion
Fri Jul 21, 2017 10:02 am
Alain
with the new update this is fixed, have you updated via OTA?
