Pappmann
[TRACKED] Android multi user settings disappeared after the 20180105 update
Wed Jul 12, 2017 11:18 pm
please enable android multi user support in Android for next firmware versions.
Im using my phone for private and business and must use 2 different user profiles to save personal and business data, thats because i buyed a dual sim phone.
Because my old BV6000 was able to root i was changing build.prop file to enable this android feature, on BV8000pro its actualy not possible because missing way to root the phone.
Thx
Re: please enable Android multi user support
Thu Jul 13, 2017 7:39 am
We will report your request to our person.
Pappmann
Tue Aug 08, 2017 4:34 pm
Is there any update about that request???
Fri Aug 11, 2017 8:39 am
We will inform you if we receive any news.
SarnMitsun
Thu Aug 17, 2017 9:17 am
I would also like the activation of the MultiUser feature. Its only a simple and small change. Worked great on BV6000.
Why it is deactivated per default? Its a great feature for Multi-SIM devices.
Pappmann
Mon Sep 18, 2017 5:54 pm
there are any news?
Is there a way to build a stock android 'SystemUI.apk' für BV8000pro?
MB242
Thu Sep 28, 2017 4:32 pm
I'm running alternative ROM + root and just added two lines to build.prop:
fw.show_multiuserui=1
fw.max_users=3
I believe Blackview can do this too for us in the next ROM release
Pappmann
Re: please enable Android multi user support [workaround]
Fri Sep 29, 2017 11:18 am
Hello, yes thats no problem but u cant switch between users, because of the missing User switch button in the Statusbar/Quicksettings Menu.
All we need is a SystemUI.apk with a stock android Statusbar/Quicksettings Menu.
Here is a example of BV6000 with Android 7:
MB242
Sat Sep 30, 2017 2:53 pm
Can you share BV6000 SystemUI.apk?
war_horse
Mon Oct 02, 2017 1:20 pm
fw.max_users=3
which alternative rom are you using actually? it sound very interesting, maybe can you make a post about it? thank you
