akitaro
Process system isn't responding....
Wed Jul 12, 2017 10:58 pm
Hello everyone,
This morning I got this message "Process system isn't responding. Do you want to close it ? Wait / OK." and nothing happens if I press Wait or OK.
I am limited to Restart/Shut Off and can't do anything else with it. I've tried restarting in safe mode but it only does a regular restart.
What are my options in this case ? Should I contact the seller to get it replaced coz it's only 7 month old so it should be under warranty still,
Re: Process system isn't responding....
Thu Jul 13, 2017 10:20 am
If that message comes again and again you may try a update or/and a factory reset.
(If possible save your personal files before that, they may get deleted through this)
