stefanocbr
Touchscreen problem
Wed Jul 12, 2017 8:51 am
Hi I have a bv7000 pro build ID 20170609 2017 0609 1815 this is the last relase? :roll:
Do I have a problem with calibrating the touch screen? And the battery does not last long.
This Flash ROM of BV7000_PRO_Blackview_20170622 to upgrade OS 7.0 is better than mine or is it the same?
Thanks for your advice
Re: Touchscreen problem
Wed Jul 12, 2017 10:40 am
For the bv7000PRO the latest version is 20170622 in the moment. It is different to your older version.
stefanocbr
Mon Jul 17, 2017 9:33 am
Thanks for the answer, I updated with this rom but the touchscreen and battery problem remains. How can I do?
stefanocbr
Mon Jul 17, 2017 9:35 am
Wed Jul 19, 2017 11:59 am
Check for a newer update again and try a factory reset.
Please report if it helped.
stefanocbr
Wed Jul 19, 2017 4:06 pm
I have already updated this ROM 20.170.622 so with smartphones like the factory but the problem persists. What is the last rom?
Thu Jul 20, 2017 10:49 am
Here: viewtopic.php?f=176&t=191529 you find the latest version.
It's 20170717 or 20170717 (depending on your device version). It should be available over OTA update.
Роман
Fri Jul 21, 2017 7:09 am
сенсер перестал работать обновил до заводских только кнопки с боку работают
stefanocbr
Fri Jul 21, 2017 7:46 am
Updated with OTA but still touchscreen problems, better battery
Tue Jul 25, 2017 1:43 pm
Flashing the latest version may help better than the OTA update. Please always try a factory reset after updating if you have problems.
If nothing helps to solve your touchscreen issue you may exchange/repair the phone over your seller.
