serviziinformatici
Car carher compatibility for BV7000PRO
Mon Jul 10, 2017 9:03 am
we bought 100 BV 7000PRO for our company and we need tro provide to our operators a car charger with quick charge.
We found this one: Samsung Type C / EP-LN915CBEGWW (http://shop.samsung.ch/it/samsung-car-c ... pid/457105).
Is it compatible with BV7000pro? Will quick charge work? (using BV Cable)
Thanks
Re: Car carher compatibility for BV7000PRO
Tue Jul 11, 2017 1:36 pm
I can not test the linked charger by my own but I think charging will work with it and the BV Cable.
It's the best you test out with one charger first how fast the charging can be because the "fast charge" of the samsung charger may be an other technology than the BV7000Pro is using.
Holefighter
Tue Jul 11, 2017 2:30 pm
I have the same, it works fine
serviziinformatici
Mon Jul 17, 2017 9:56 am
perfect, thanks!
Tue Jul 25, 2017 2:20 pm
Thank you!
