pfavayi
over heating on android nougat 7.0
Sat Jul 08, 2017 6:13 pm
I just bought my blackview P2 and I flashed android nougat 7.0 one and half weeks later.
I notice heating/over heating WHEN CAHRGING the the phone - is this normal ?
Re: over heating on android nougat 7.0
Wed Jul 12, 2017 2:36 am
the phone heats up because of the quick charging, energy equals heat the more current you put through something the hotter it gets
pfavayi
Wed Jul 12, 2017 12:55 pm
The way the phone is overheating during charging , the temperature is so high I don't think its going to last 6 months before the battery gets burned out/destroyed from the high heat.
I want to disable fast charging but I can't find where to do so in the settings.
Can you help please ?
pfavayi
Wed Jul 12, 2017 1:00 pm
Blackview P2 also heats up when I am using it normally and without connecting to the internet.
My other two phones - jiayu s3 (on custom ROM resurrection remix 7.1.2) and Samsung galaxy grand neo plus (on stock ROM) don't heat up when I am using them in a similar fashion.
When I use WiFi or data , blackview p2 heats up much more than the other two.
ashboe
Tue Aug 01, 2017 1:08 pm
I do notice the phone getting hot when in high use, however I don't think it is more noticeable than other phones I have had
