Andreas2
No service while charging battery
Thu Jul 06, 2017 1:10 am
New BV6000 purchased from Gearbest. Signal drops and i have no service when charging phone. Tried different chargers without success. Anything I can do to try to fix this problem?
Re: No service while charging battery
Fri Jul 07, 2017 10:15 am
Have you installed the latest firmware 20170517?
Andreas2
Mon Jul 10, 2017 4:19 am
yes
Mon Jul 10, 2017 2:06 pm
If you have NO signal while charging with original Blackview cable and Charger please contact your seller for help.
Andreas2
Tue Jul 11, 2017 4:52 am
I have a weak signal where I live. When i charge the phone here it kills the signal. I tried charging in an area with a better signal and it doesn't kill the signal completely there. I imagine if I sent the phone in for warranty I would be told it is fine.
Tue Jul 11, 2017 7:13 am
Are you using the ADB interface?
When charging new phone it losses singal, so it is unusable while charging if you are using the ADB interface.
Andreas2
Tue Jul 11, 2017 2:02 pm
I am not knowingly using ADB interface unless it is preinstalled and i don't know it
Andreas2
Tue Aug 01, 2017 5:01 pm
I have had a lot of problems with bugs with this phone since a got it a month ago or so. It was ok with calls and texts unless it was charging. Yesterday i disabled settings/battery/standby intelligent power saving. This seems to have fixed a lot of the problems I was having. It charged up last night without losing signal. Another problem was restarting at random times and is not doing that since yesterday. apps that use gps and other sensors when in standby mode seem to be working a bit better now. The compass (magnetometer) still does not work though. I will post again if any of the problems reoccur.
Wed Aug 02, 2017 8:34 am
thank you for your feedback! this may help other users
Andreas2
Wed Aug 02, 2017 2:54 pm
Unfortunately the charging and loss of service problem still exists. The setting change did however improve the performance of the phone. It is unfortunate this has happened because it was my first experience with a Chinese brand phone. It seems to be well built at a good price but problems with the hardware and software are probably a deal breaker. It is too expensive and time consuming to send it back for warranty. I will get back to the seller and let them know too.
