Falvy
I'm having some problems with the BV5000 USB connection.
Sat Dec 26, 2015 10:07 pm
The phone used to connect normally to the laptop the first few days i have gotten it.
Though one day i have tried the "Mass storage" option for the USB from the phone pop-up in the status bar which is reccomended for XP but i have Windows 7 and i might have done a mistake because now the phone won't connect to the laptop anymore and it won't display the USB connection options in the status bar anymore when i connect the usb cable to the laptop. It only charges the phone. Also i have my "Removable Disk H" permanently on My Computer. Ejecting it won't help, and it is what i used to connect to the phone.
Isn't there some way to change the options of the USB from the settings or something? I tried to look for some USB settings all over my settings but i could not find a single thing.
Also i've tried using the USB debugger, checking and unchecking it but it does not work at all..
What am i to do?
Should i try to get a new data cable or i just won't be able to transfer data from my pc to my phone anymore?
Re: I'm having some problems with the BV5000 USB connection.
Mon Dec 28, 2015 10:03 am
Hi ,
have you ever change to try on another computer or use anothr USB Cable USB ?
Best regard,
Admin
