Stephan959
7000PRO voice volume too low
Wed Jul 05, 2017 12:07 pm
in my 7000PRO during the normal phone conversation the volume of the ear speaker is very low, and in case I stay in noisy area is very uncomfortable.
If I use Skype the ear speaker is OK and its volume is OK.
Do you know if some upgrade is available to fix that?
Many Thanks in advance.
Re: 7000PRO voice volume too low
Wed Jul 05, 2017 1:28 pm
Have you updated your software to the latest version 20170612?
Lurk
Wed Jul 12, 2017 11:53 am
Hello my friends.
I have the same problem with ear speaker. The sound is very low.
I solved a problem by changing network type 4G to 3G.
I don`t know why but it working. :D
Stephan959
Wed Jul 26, 2017 11:07 am
I've just upgraded the phone with Android 7.0 and the speaker volume now is OK. (Build 20170706)
But after that the phone reboot sometime automatically by itself...
Mon Jul 31, 2017 12:33 pm
This is the forum for BV7000.
You can find help for BV7000 Pro here: viewforum.php?f=173
