bvbw
Spooler impress problem
Mon Jul 03, 2017 9:09 pm
I cannot print with the command "print" in various apps (ex Gmail, Office suite, ... etc ...) message is "Spooler impress stop"
I can print any file txt pdf jpg with special print apps (brother, hp, ...) without problem !
Is it possible to give me a patch for re-install the Spooler impress service in system apps or i have to flash over the rom to fix it ?
Thanks
Re: Spooler impress problem
Tue Jul 04, 2017 2:22 am
Thanks
Have you tried clearing the apps cache?
bvbw
Tue Jul 04, 2017 2:27 am
Yes, no success.
bvbw
Tue Jul 04, 2017 4:03 pm
Is it a bug only in my phone or a ROM problem more general since update Nougat 7 ?
Can some users test print command in GMail app ?
Thanks
Wed Jul 05, 2017 1:18 am
Thanks
Try downgrading to see if the problem persists.
bvbw
Wed Jul 05, 2017 3:14 am
No thanks, i don't want ... Too many bugs in previous version ! Hope next version will fix this problem for me ...
