karera
Downgrade to Android 6 problem
Mon Jul 03, 2017 6:50 pm
When I tried to downgrade to Android 6 20170523 from Android 7 20160722 my phone reboots itself then stuck to Blackview logo. And when reflash to Android 7 it says "com.android.phone has stopped". How can I solve it. Help please.
Holefighter
Re: Downgrade to Android 6 problem
Mon Jul 03, 2017 7:31 pm
Factory reset?
karera
Mon Jul 03, 2017 8:03 pm
Holefighter wrote:
Factory reset?
When I chose "Recovery Mode" it says "no command". Do you know the difference between Download Only, Firmware Upgrade and Format All + Download?
Holefighter
Mon Jul 03, 2017 8:22 pm
If you want to flash with spflash you habe to choose download only. Dont try anything else!
Tue Jul 04, 2017 2:44 pm
karera wrote:
Holefighter wrote:
Factory reset?
when you see "no command" press power and volume+ again
karera
Wed Jul 05, 2017 3:44 pm
blackview_admin wrote:
karera wrote:
Holefighter wrote:
Factory reset?
Thanks a lot
