inventor4fun
[SOLVED] Bv8000 pro restart - power button problem
Mon Jul 03, 2017 12:27 pm
I received the smartphone Friday, the first days have gone well but now continues to reset.
I have done a hardreset but the problem continues, what can I do?
Is there a service center in italy?
Thanks
Re: Bv8000 pro restart automaticaly
Thu Jul 06, 2017 7:50 am
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now
bulahasis
Fri Jul 07, 2017 3:08 am
I had the same problem...
Turn off "Prevent pocket dial"
inventor4fun
Sun Jul 16, 2017 1:45 pm
It was a botton problem!
The button locked pressed
Zeerch
Fri Jul 21, 2017 10:04 am
everything ok with your phone now?
hanindiyos
Re: Bv8000 pro restart automaticaly, SOLVED
Sun Aug 20, 2017 7:23 am
My phone reboot automaticaly after push power button. i just open the right cover and check the button but no problem with power button I think. and now still restart automatricaly. i had tried for flashing with latest 20170718_s21v57c2k_jk_fsm rom. still restart / bootlooping :(
