oulie
Apps
Sun Jul 02, 2017 1:07 pm
i have a very strange problem with this phone apps keep opening randomly without me touching the phone
Has anyone had this happen to them or a way of stopping it
apart from this i like the phone and want to keep it
oulie
Re: Apps
Wed Aug 02, 2017 10:29 am
If it don't help please provide a video to show how the apps open without touch
oulie
Re: Apps
Wed Aug 02, 2017 4:32 pm
I had the same problem I returned the phone back to Amazon
But I like the phone and ordered another and all is working fine
Re: Apps
Mon Sep 18, 2017 5:33 pm
thanks for your feedback
